best way to hook up
99concorde
laughing at you
ive got this amp(1300W X 1 Bridged 2 Channel High Current Amplifier
2 x 130 WRMS @ 4 ohms; 2 x 250 WRMS @ 2 ohms; 2 x 375 WRMS @ 1 ohm; 2 x 650 WRMS @ .5 ohms ; Bridged: 1 x 500 WRMS @ 4 ohms; @ 2 ohms 1 x 750 WRMS @ 2 ohms; 1 x 1300 WRMS @ 1 ohm; Dimensions: 11-1/2" (W) x 2-1/2" (H) x 17-3/4" (L). Bridgeable, Tri-Mode Capable; Low Level Inputs; Bypass Line Output For Connecting Multiple Amplifiers To The Same Signal; Variable Low-Pass Filter 45- 1220 Hz; Variable High Pass Filter 100-800 Hz; Variable Bass Boost 0-18 dB; Variable Bass Boost Frequency: 45-90 Hz; Variable Phase Shift: 0-180 Deg; Variable Output Level Control; Thermal, Short Circuit & Overload Protection; VU Meters; Cooling Fan ) its an ma audio 1302.
I want to hook it up to these speakers(
Alpine SWE-1241 12" Type-E Series Subwoofer (4ohm) ))
Ive got two of them in a sealed box. what would be the best way to hook them up to get the most whats to each.
sorry if this is a dumb question. also what does variable phase shift mean and what should it be set at.
Originally posted by 99concorde ive got this amp(1300W X 1 Bridged 2 Channel High Current Amplifier
variable phase shift controls how the sub fires. you use it when you mount your sub firing INTO the box usually. put it at 0 if your sub is facing out of the box, 180 if its facing into the box.
as for wiring, your options are 8 ohm and 2 ohm. id suggest 2 ohm by wiring them in parallel.
99concorde
laughing at you
99concorde
naptown
mattj
