best way to dynamat the doors
randomwalk101
From looking at a lot of pics, most dynamat their car's doors on the inner side (side that is closest to the plastic panel cover). I know a few people dynamated the door skin (right next to the glass)..however is very though to reach in there.
Which is a better method to dynamat? What is more effective in term of sound deadening?
I just finished damping my entire truck.
Each door got about 40 sq feet of Damplifier //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
3 layers on inner door skin (thin metal close to outside of the car)
2 layers reverse of outer door skin (backside of part door panel attaches to)
2-3 layers on front of outer door skin.
I also used 1 layer of closed cell foam, and 1 layer of carpet padding on the inner skin and reverse outer skin. I used a material similar to Damplifier (only sticky on both sides) to attach the foam to the doors.
I recommend putting the material everywhere you can, as long as you can still put your door back together and have it work right.
Email me if you have any questions.
ANT
randomwalk101
randomwalk101
Houston,TX
mgaidica
