theothermike
I HAVE NO LIFE, CA = LIFE
Right now im running a sae-1000D and 100.4 sundown amps, however in next 2 months i should have my 100.2 so i can run active 3 way front stage and another sae-1000D so im making around 2000.
Problem is 4 amps? and all the wiring is a nightmare to plan
What is the best way of wiring my system
here is my wiring as of now
I got all my big 3 done in 1/0 gauge and fused the alternator run. I have a larger capacity battery under hood. then there is a 1/0 fused power run to another smaller battery in my trunk. from this battery there is another 1/0 gauge run to a distrobution block where it is seperated into 2x fused 4 gauge power runs into my 2 90amp rated amplifiers......
I have a set of 4 channel knu krystals running from headunit. and another 2 channel klarity running to my sub amp....
Here my plan LMK if this is the best way to rewire it with 4 amps....
The 100.4 and 100.2 both have a set out seperate preouts i believe to hook up another amp and transfer the signal..... I plan on running a 1.5 or 3' set of 2 channel rca krystals from the 100.4 to the 100.2.
I also plan on running a single mono rca from the bridge output into the bridge input rca of the other sae-1000D.
Do i need to run another set of rca 2 channels as well for the other sae-1000D?
I plan on adding another 1/0 gauge run and purchasing another kf-12 knukonceptz fused distro for the other 2 amps. and another ground distro for the other set of grounds.
I really have to figure out if my slave 1000D being bridged as requires a set of 2 channel rca's. if so im ****ed and have no clue what to do.
Mike-
EDIT: the slave being bridged does not require another set of rca's just a single mono cable. between bridging output and input. hurray
Mike-
