Best sub for this amp
Im looking for a sub that can handle long hours of pounding and sounds good and not expensive somewhere around $200
601SE 2 Channel (Stereo) Power Coustic Amplifier*
600 Watts***
Triple Darlington Drive Circuitry*
Adjustable Bass Boost*
Built-in HPF / LPF with Continuously Adjustable Crossover Frequencies*
Remote Subwoofer Level Control Ready*
**RMS Power 4 Ohm Mono at 14.4V
SPECIFICATIONS
Rated Power @ 14.4 V (0.1 % THD) 4 Ohm Stereo 2 x 150 Watts*
Rated Power @ 14.4 V (0.1 % THD) 2 Ohm Stereo 2 x 300 Watts*
Rated Power @ 14.4 V (0.2 % THD) 4 Ohm Mono 1 x 600 Watts*
Input Sensitivity 0.1 - 5 V*
S/N Ratio @ Rated Power 100dB*
High-Pass Filter Crossover Frequency 30 - 300 Hz (Cont. Variable @ 18dB/oct.)*
Low-Pass Filter Crossover Frequency 30 - 300 Hz (Cont. Variable @ 18dB/oct.)*
Bass Boost Level 0dB - 18dB @ 45 Hz
COMMON FEATURES
CARBON FIBER DESIGN HEAT SHIELD*
ENHANCED DYNAMIC PERFORMANCE*
WIDE-RANGE INPUT SENSITIVITY ADJUSTMENT*
BUILT-IN CROSSOVERS*
LINE OUTPUT*
THERMAL, OVER CURRENT, SHORT CIRCUIT AND DC OFFSET PROTECTION*
2 OHM STABLE*
BRIDGEABLE*
SPEAKER LEVEL INPUT*
SOFT-START TURN-ON AND MUTED TURN-OFF*
POWER/PROTECT INDICATOR
Audiobahn is garbage.
ya id say no one audiobahn since thats sadly what im running right now. i just sent one of the motors and baskets off to splaudio to make me something good.
junior_tm
junior_tm
Atlanta, Georgia, United States
SpeedEuphoria
