best SQL setup? 3 Assasin 12s? 2 Arsenal 12s? 1 IDMax?
Where could I acquire an Arc Flatline subwoofer brand new for $300?
What ohm load would 3 4ohm drivers wire down to?
Is it true that you gain roughly 6dB of output by adding an additional driver of the same driver and using the same power. Lets say if you owned 1 12 with 88dB efficieny and you fed it 1000 watts, if you added an additional driver and gave both 12s the same power (500 to each) would you have the same output with an addition of 6dB? If this is true, what are the possibilities for more than 2 drivers?
...I do not have the funds, a dealer nearby, or any other resource to hear any of these systems. I am asking what should be theoretically louder with only 1000 watts?
The sale ends at the end of next week, I believe (each setup would cost roughly $300, 3 12s, 2 12s, or 1 12)
I believe they mentioned it in the Loudspeaker cookbook (Ive got the 6th edition), but im too lazy to look. Can anyone confirm this for me?
no, you'd theoretically gain around 3db. The formula used shows SPL as purely a function of displacement. Displacement (amount of air moved) is controlled by 2 main factors. The size of the driver that is moving, and the distance it moves. If you double any of these factors you double displament, gaining 3db. If you were to add a second sub, you'd double your cone area. However, since you split the available power between the 2 amps, you lose excursion. Since the strength of the magnetic field is NOT directly porportional to the distance the cone moves, if you half the power you wont' half the distance (theoretically). You have 2x the area moving 70% the distance each, half power is a 30% drop off.
What is the equation for finding impendance?
if I had 2 DVC 4ohm subs would it be (4 x 4) / (4 + 4)
impendance X impendance divided by each of them added together?
your correct in some ways but not fully. to theoretically get a 6db gain you have to have that woofer of off a 1000 watts and add another with a 1000 watts. they way you described is only a 3 db gain. but this is all install depended and a lot of other factors. you have to doudlbe surface area and power to get 6db's. and http://www.sounddomain.com/shop/wooferwizard.pl?num_of_subs=2&impedance_of_subs=4ohm_dvc&x=103&y=5
use that for wiring purposes
thadman
thadman
Indiana
takeabao
