Best SQ DC sub?
Of their subs the Level 3 and Level 4 appear to be the most oriented towards sounding good and getting loud. Personally I wouldn't even consider them if I were looking for SQ, only a few subs make my short list for SQ and DC isn't on it.
Level 4 XL 15 that I had sounded good. I wouldn't quite call it an SQ sub, but not bad at all while getting very loud. The XL sounded better that the Level 4's that I tried fyi....
I've used LV4XLs in 10'' and 12'' and LV4s in 12'' and I thought the LV4s sounded better on music. The LV4XLs can also sound good but the LV4s sounded better in my opinion.
Level 1
The Level 1 sub is "Bass on a Budget".
When we sat down to design this driver we were looking at making an in-expensive sub with great SQ and lots of output. Because there are a lot of entry level subs out there, we wanted to make sure that anyone who buys a DC Level 1 get everything and more in comparison to how much came out of pocket for it. I think we did just that.
Level 2
This is one of our greatest accomplishments. It’s a sub that has everything you need
in a daily driver except the cost.
The Level 2 starts out with a double-stacked FEA optimized motor wrapped in a magnet boot with a chrome top plate and T yoke to keep it looking good.
It has 18 mm of X-Max, progressive spider, 2.5" voice coil, cast basket, push terminals
and a under rated suggestion of 300w RMS/600w peak power handling.
This sub works great in sealed or ported enclosures and defiantly gives you more bang
for your buck!
Key Features
• Extremely rigid non-pressed paper cone assembly
• Multilayered polymer foam surround
• Polypropylene dust cover with embossed DC logo
• 8” OD flat linear roll spider
• Heavy duty interweaved tinsel lead wire
• Cast aluminum black frame
• FEA analyzed and optimized motor assembly - Fully CNC machined
• Rubber mounting gasket
• Chrome spring loaded push terminals
• Dual 4 ohm 2.5” Hi-temp Aluminum voice coil wound on black
anodized voice coil former
• Rubber magnet cover
Kevinn
Kevinn
St.Louis
Kevinn
vegang
vegang
