Best SQ amp on budget?
XtheoneandonlyX
27
la
What would be the best amp to use to power a set of Rainbow C365 profi vanadium kicks (i think peak is 180 and rms is 150...its been awhile since i messed with them) for under $700. I have them in a project car (07 mustang gt), and I am looking to get really good SQ in it. Any help would be greatly appreciated.
The amp is the least important part of the equation. I wouldn't use a Pyle amp for reliability reasons and the fact that it won't make much power before distortion becomes audible. What I would use is the most powerful decent amp I could find. I would then detune it to keep it comfortably within its low distortion linear range. Pretty much any decent amp will be more than up to the task of powering a SQ oriented system.
thanks for the posts, Yeah i had them temporarily hooked up to a us amp 2100 i think... it was ok but not very reliable. but it was the only thing i had at the time...
well i have my subs on identical one, they are soundsplinter rl-i8s. For the subs the amps are fine. but the comps keep cutting out at 2/3 volume on my deck which is at like @ 42 of 62. (pioneer i don't remember the numbers, it was a average quality. I think the DEH-P9800BT is the newer model.) I have rewired the entire car, and have tried to make the trunk extremely cool, but yet i still have problems, so I plan on just replacing the amp.
Put 300W on themwith an Arc audio SE series. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif or an audison LRX 2.9 will do the job.
for 700$ there's many option for good ,clean , reliable amps.
Arc audio ks 300.4. 90 watts x4 at 4 ohms. 175 watts x 4 at 2 ohms. S/n ratio 95 db's. $258.70 at audiophileliquidator.com and they match the manufacturs warranty. And take the remaining $ and get an arc audio ks 1000.1 for the subs. 850 watts rms at 4 ohms. 1000 watts rms at 2 ohms. 1000 plus watts rms at 1 ohmn. S/n ratio of 112 db's. $388.70 at the same place I mentioned above.
XtheoneandonlyX
XtheoneandonlyX
la
denim
