best sound deadner....
prioracy
i pack da magnums
Sup guys i need opinions on what kind of sound deadner i should use, i currently just got my orion 2500d fixed and i have it hooked up to 3 12" memphis m3s. Right now i have some dynamat extreme on their but it isn't really doing the trick, i just need it for the trunk i used peel and seel for the botom of my trunk and it works like a charm. I used peel and seal on my trunk but it just ended up falling off so, should i buy second skin or eD peel and seal type or should i go for the liquid form. i did a search but still kinda iffy and wanted opinions. oh and by the way these puppies get LOUD!//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
I wouldn't use eD mat if your p-n-s fell off already //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
SecondSkin Damplifier would do you well. High heat tolerance..should hold very good. You could use more Dynamat Extreme if you can find it for a reasonable price.
I'd recommend Raammat...but it only comes in 62.5sqft rolls....and it doesn't sound like you intend on using that much.
And I'd avoid liquid....that shit is a PITA to deal with when applying it to verticle or overhead surfaces, IME. Sludge would work though, since it's more of a paste.
prioracy
i pack da magnums
prioracy
chicago, IL
squeak9798
Mike Mccabe
