I have two type r's that I'll be putting in a hummer h1 wagon.
One enclosure on each side of the rear wheel well.
I'm thinking about this box i found on hifisoundconnection.
what do yall think about it? Is it the best one that will be perfect for the type r's?
any additional info would be appreciated. thanks in advance.
Vented Sub Box Enclosure Single 12" Subwoofer
Vented-Sub-Box-Enclosure-Single-12-quot-Subwoofer-image-2 Vented-Sub-Box-Enclosure-Single-12-quot-Subwoofer-image-3
One of the best way to get the maximum bass per watt is a vented enclosure! This single 12" enclosure will work with almost any brand and model subwoofer(s) just be sure to check the recommend airspace required. Unlike a sealed box the vent allows air to freely move in and out of the box but is "tuned" to a set frequency range that greatly increases the overall output. More air = more bass! This enclosure features a special black spray on coating that is comparable to bed liner spray. It not only makes for a more cosmetically pleasing look but is also a protective water resistant shell!
Our boxes are made from precision cuts of MDF. They are then liquid nailed, nailed and completely sealed. We then wrap them with high quality carpet that matches most vehicle interiors. All Boxes feature high grade spring loaded terminal cup(s) for the absolute best connection possible. All the custom series enclosures are made to fit precisely into your vehicle to the get the max performance from every extra inch of wasted space.
We guarantee you will not only see a difference in the quality of the boxes we build, but you will hear the difference and that is what is it is truly all about.
Product Code: RL112V
Features:
* Single 12" Vented Sub Box
o Mounting Depth: 15"
o Air Space: 1.60 Cubic Feet
o Vented Enclosure
o Dimensions: Width 18" x Height 13" x Depth 16"
* Vented Design allows for maximum output
* Constructed with High Quality MDF
* High Quality Binding Terminal Cup (Accepts Banana Terminal Plugs OR Bare Wire 'up to 10GA')
* Seven Sprayed on layers for a long lasting, durable, water resistant enclosure (same technology as spray-on bed liner)
Features:
o Vented Enclosure
