whitedragon551
Moderator
Simply not true. An amp can clip well before or well after 1/2 gain. All of them are different. Headroom is a good thing, but only if its unclipped. Also a clipped/unclipped signal with bass boost is a moot point. You should NEVER use bass boost on an amp or on the headunit ever.It is actually good to have a amp that puts out more power than what your speakers are rated at, especially if you are going with a budget amp. You don't want to run a amp at full gain anyways. Most amps clip at or alittle before half gain anyways. Running a bigger amp than what you need and turning the gain down alows it to run cool and puts out a nice clean signal. I scoped my mb quart amp before I hooked it up to my morels and it didn't quite make it to half gain before clipping the signal and that was with no bass boost or anything. Polks are ok, we put a set in my buddies s-10 and they sound descent just dont pick up alot of detail like my morels do. I hear so much stuff in my speakers that his polk db's don't.If you are looking for coaxials both Hertz and Morel make some very nice ones that get good reviews, but depending how much you like music and how comfortable you feel with your install skills componets are a worthwhile upgrade from coaxials.
