Best material for box.
The best all around material that can cost anything is a contradictory sentence //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The best all around material for building would be MDF, 3/4". It's strong, dense, cuts easily, and is the best value for the amount you get.
The best around overall would have to be baltic birch, 13 ply though. If you're in a store and it looks expensive, then it probably isn't baltic birch. You have to go to a high quality lumberyard or cabinetry business, and is usually around 60-80 per sheet (not 4x8 either). It cuts like a chainsaw through butter, holds like grandma and looks beautiful when finished.
I have yet to have any form of birch cut easier than MDF. I hate how I keep reading that everywhere; it really makes me fell ripped off. It does cut nice but I've had some MDF that slid through the table saw like it was already cut -- no strain on the motor and no hold ups at all. And yes, I've used the $65 5x5 sheet of 13 ply, no void, baltic birch.
MDF does cut easily, but if done correctly, plywood is smooth sailing throughout. It also routes cleaner as well. But note: I only use birch for home audio purposes.
i was talking bamboo plank. which i have seen in 1" thick 12x8 planks just like regular carpentry/woodworking material.
it would be a fair amount of work glueing it all together and whatnot then cutting it down and or planing and whatever.
i just like woodworking and using unusual materials to build things :/
Explain, "done correctly" please. I've tried it cutting against and with the grain and it's never as easy as the dark MDF that Home Depot usually carries. The lighter MDF doesn't cut as nicely as the dark but it still cuts easier than MDF. Birch does route easier though.
Done correctly means having the proper blade teeth and height. Otherwise, you can burn the wood or chip the veneer.
crfracer290
crfracer290
Texas
bjfish11
