Any 95/5 solder will work the same you can pick the stuff up at lowes or Home Depot. Make sure your copper and terminal is clean, I like to use a 1/2" fitting brush to clean the terminal and use a little soldering flux in the terminal, heat it up and just dab the solder when the temp is just right the terminal will **** it up like a champ.
