Best Extremely Shallow Mount Sub?
Disarmer
I recently picked up an '04 Jeep Wrangler. I'm looking to build a tiny box inside the rear seat and I'm trying to figure out which sub(s) to choose.
It needs to be able to fit inside of this box. (Someone else's plans, I have no other details on it)
I'll probably be using an AP15001D as my amp, but could change that in favor of something else if I need a different power range.
I really don't know many subs in the shallow mount category, so I was hoping you guys could help me out. Not opposed to anything at this point.
Thanks
EDIT: I don't plan on running three subs in this box. One, MAYBE two. Sealed as well. Would like to stay under $200 for sub(s) if possible.
How shallow do you need, depth wise? The JL shallow sub is pretty bad ***, the only shallow sub I would really suggest other than the Stereo Integrity's BM mkIII
I just need it to fit in the box design posted in OP. Not exactly sure how much of that 4.375" I could actually use.
I'm thinking if I ran 8" woofer(s), I could mount it as high as possible on the box and get most of the 4.375" out of the depth. With a 10" woofer, the magnet will be a bit further down, losing a bit of the depth.
EDIT: Only problem I have, is that the only decent 8" woofer I know of that could even come close to fitting would be the original E8. Any other ideas?
I've been looking at the MB Quarts 8inch subwoofers
Dual Voice Coil
200 watts RMS
400 watts Peak
Frequency response 35-120 HZ
Resonance Frequency 41.5 HZ
Sensitivity 81.23 DB
I think the Mounting Depth is about 3 inches
on ebay they cost $65
I been thinking about purchasing 4 for my Volvo C70 but haven't done it yet.
Disarmer
Disarmer
Mexia
ducatipaso
