Best Box for JL 12" w6v2
Pineapple
Whats the best box for a single JL 12" w6v2 running off a JL 500/1? Wouldnt the H.O. Wedge and ProWedge boxes made by JL be the best? Or would getting a custom box made be better?
Which box is better for my 2001 Tahoe? the H.O. Wedge or the ProWedge?
If money is no object go with the H.O., but you can still save some $$$ and built your own enclosure to JL specs, you can find them online. //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
I will recommend you a ported enclosure for such a large vehicle. //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
//content.invisioncic.com/y282845/emoticons/2thumbs.gif.fdc3ba010dbb42b61704534b46d02fe4.gif
The HO box would be better if you want a bit more kick for your larger vehicle, since it is a special JL designed port (no one else can make boxes like that, JL has the patent). A JL 500/1 is the perfect amp for that sub so no worries there, good luck.
Joel
I think you really should just build your own box. That way you get to choose all the parameters which will determine how your install sounds. It is not as hard as it seems and there is plenty of tutorials located on these forums.
Pineapple
Pineapple
San Jose, CA
ighettoboyi
