Best and Cheapest amp for a super sub?
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif thats freakin cheap WTF is Boss though? Im getting an extremely good subwoofer, i really don't wanan buy a peice of garbage for the amp
Its just overrated powerwise, inside you will find a common classD korean circuit board that works just fine.
Amplifier Type: Mono
RMS Power: 1200W x 1 @ 4 Ohms (800 actual)
THD at 4-Ohm RMS Power: 0.05 % (.1 actual)
RMS Power: 1500W x 1 @ 2 Ohms (1000 actual)
Speaker Level Inputs: No
Preamp Outputs: Yes
Built-In Crossovers: LP
Bass Boost: 0 - 18 dB
Frequency Response: 15-250 Hz
Signal to Noise Ratio: >100 dB
Fuse Rating: n/a
Shipping Weight: 8 lbs
Warranty: 6 years
Boss does not design their own amps, they use old amp designs from major manufacturers and get them built in China or Korea where the labour is super cheap.
The big problem with the quality is that they will take (for example) a 500watt RMS 2ohm stable amp and market it as a 1000 watt RMS 1ohm stable amp, then when people try to get 1000watts at 1ohm they start having problems.
If you cut through the misleading ratings and use the amp properly it will work and sound fine.
Cheap Rca's Sound Dirty And Pick Up Road Noise . Get A Good Set .
I have used cheap 5dollar RCA's for the past 10 years in all my installs and never had problems with noise.
Its all about the install.
Yeah Thats The Problem "cheap Labor " When Is Everyone Gonna Realize That This Will Be The Downfall Of America ? Keep Buying That Crap And We Will All Be Out Of A Job .
And you know what guys? Im not even positive i want the RL-P!!! I keep jumping back and forth between the RL-P and the IDMax!!! This sucks!!!!
ls1pimp
ls1pimp
NJM
Mr. Opportunist
