Best Amplifier Choice?
Boofster
I have two kicker 11S15L34's and i was wondering what would be the best amp i could buy for around $250. I am a bit of a rookie and i would really love some advice.
I tried adding a link to my subwoofers but i was unable as this is a new account.
Do you want to run the set @ 1 ohm or 4 ohm final impedance? This will make a huge difference in the amps you should be looking at...
Size is not an issue as the subwoofers are in my trunk, I would prefer running them at 1ohm but if you guys can show me some amps that would better suit them running at 4ohms i am open to ideas.
OK, if I was you I would try to find a used Sundown SAZ-1000D, or a Used Digital Designs CM1000 amp, Either of which are very good amps, & both will push 1k @ 1 ohm... I wouldn't overpower those kickers by going over 1000 watts rms @ 1 ohm if you want them to last at all.... Just my .02
Definitely solid advice thanks. However if i wanted to buy new equipment what route would i want to go? I'm weird when it comes to used electronics.
Boofster
Boofster
Florida
