best amp for
subs don't push out watts //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif we also need to know the voice coil configuration of the subs & your budget
is the hifonics zxi1010 a good amplifier? i hear a lot about hifonics
the amp specs:
Zeus ZXI 2-Channel AB Car Amplifier
RMS Power Rating:
4 ohms: 250 watts x 2 chan.
2 ohms: 500 watts x 2 chan.
Bridged, 4 ohms: 1000 watts x 1 chan.
Max power output: 1000 watts
Ultra-Fi MOSFET power supply decreases distortion and produces high fidelity
Wired remote bass level control included.
LED power/protect indicators
Bass Boost: (0-10 dB bass boost at 45 Hz)
Soft start sound
2/1 Channel operation
Preamp RCA outputs
RCA level inputs
Screw terminals
Heavy duty aluminum alloy heatsink and vents for uncontested heat dissipation
Built-in system diagnostics protects from short circuits, over load, thermal over-heat and DC offset
Crossover selector for high pass, full range or low pass operation
Damping Factor: 200
Variable high-pass filter (10-150 Hz, 24 dB/octave)
Variable low-pass filter (30-150 Hz, 24 dB/octave)
Subsonic filter and level control
Frequency Response: 10-30,000 Hz
is the hifonics zxi1010 a good amplifier? i hear a lot about hifonics the amp specs:
RMS Power Rating:
Soft start sound
Preamp RCA outputs
RCA level inputs
Screw terminals
Damping Factor: 200
????? //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
ludrof11
ludrof11
erie, PA
stocker08
michigan born
    May 14, 2026
michigan born
    May 14, 2026
