MarcusFranz
Its supposed to be like 200w bridged at 4 ohms however when i use a multimeter to get the volts its putting out to calculate the actually watts it stays around 50volts ac
which would calculate to (50x50)/4 or 625... now the problem with that is im using a pc power supply to run the amp which is putting out 12volts and 15 amps which = 180 v and even more of a mystery is the fact that the amp only has 1 30 amp fuse meaning it should blow with any power over 360 watts at 12 volts??? someone got any answers to this...
model of amp is mrv-t502
