No gut shots and its marked down so much iI wouldn't trust it.
This is a good route as far as potential to growI'd consider the CAB 1600.1... buy a dual 4 ohm SA-12 and load the amp at 2 ohms (1200 watts or so)... and if you want to add a second SA-12 you can go to 1 ohm (1500 watts +) and the amp will be perfectly fine with that load... it's a little over rated power but I think a little extra is good anyways... and those SA-12's have a great reputation at being underrated... just mount the amp away from vibration (no box)... for $199 I believe it's a good buy....
yeah but we have a few peeps say the ap's have died lately and guy here got 1 new and never worked right..audiopoop 1500.1 costs the same and does 1300 watts certified so idk man. Got love for ppi but they are beat in this budget amp category. Audiopoop doesnt actually tank electricals anywhere close to as bad as hifonics. As for reliability. My buddy is a complete noob, shorted power and ground, shorted speaker leads, dropped the amp, grounded the amp chassis, daily hard clipping. Massively overheat in hot california weather. Amp still kicking, will thermal protect after a 30 min ride in the hottest conditions but will function normally without any power loss after cooling down. Amp Was bought used as well and the previous owner bought the amp used as well. All in all 80 bucks well spent.
see i still think my ppi better for u, it does 930rms at 2 ohms set gain low u be good..Really I only want 600-800rms....
I was looking at the 1500's bc I assumed Hifonics and Audiopipe would only do 60-75% of their ratings.
factory defect should be covered by warranty. If op wants an amp he should hunt the local craigslist. I always have better luck used than new. If its working then, it should be working now as long as you know what to look for and properly test it.yeah but we have a few peeps say the ap's have died lately and guy here got 1 new and never worked right..
amazon seller jb tools told him to su*k it, and he had it installed at a shop.. also see if that memphis 1100.1 still fs here it's like $120 shipped, he's a good caf memberfactory defect should be covered by warranty. If op wants an amp he should hunt the local craigslist. I always have better luck used than new. If its working then, it should be working now as long as you know what to look for and properly test it.
Zapco ST-850XMII (New Mark II) Mono Class D Amplifier https://www.amazon.com/dp/B013PUVGP4/ref=cm_sw_r_cp_api_YkeDzbDV1PKZ4Really I only want 600-800rms....
that zapco looks pretty nice! And as far as ive ever seen that company doesnt do low end, only med-hi to hi endZapco ST-850XMII (New Mark II) Mono Class D Amplifier https://www.amazon.com/dp/B013PUVGP4/ref=cm_sw_r_cp_api_YkeDzbDV1PKZ4
