Best amp for SA12?
Grendel0501
Budget is less than $200. SA12 comes in d2 or d4. Probably get D2 for 1ohm. (less power draw)
Thinking about a Audiopipe 1500d or Hifonics 1515.1d.
Cheaper amps. Looking to get 800-1000 actual rms.
Suggestions?
Also, this is going into a hybrid. Does a hybrid have a greater voltage than a regular vehicle?
For that power on that budget I would consider the soundstream tn1200.1. I don't have real world experience with this amp but it shares a decent board with some other decent amps in that range. Honestly there are a lot of amps roughly in that price range.
[quote name='Grendel0501']Budget is less than $200. SA12 comes in d2 or d4. Probably get D2 for 1ohm. (less power draw)
Suggestions?
Also, this is going into a hybrid. Does a hybrid have a greater voltage than a regular vehicle?[/QUOTE]
god no.. $200 and thats what u come up with?, get ppi p1k like mine (same as the ss already suggested peeps here love the ppi$166) i'm running mine at 2 ohm it's strong (tested at 1162 @1ohm).. but for $200 u can also get a cab it's a big amp main reason i never looked at it but @shredder1 will tell u about them.. u could even get the skar 2k for $229 it tested at 2200 and run it at 2 ohms
Suggestions?
here it is guy here think his name is gotgixers is putting 4 of these in his big build https://www.amazon.com/P1000-1-Precision-Power-Monoblock-Amplifier/dp/B005KW10ES
Suggestions?
sorry that seller on amazon ***** get it from one to right and down car audio closeout it's $168 jb tools screwed guy on here.. just check seller on ebay or amazon b4 u buy, here's a low end fav https://www.amazon.com/Rockford-Fosgate-200-Watt-1-Channel-Amplifier/dp/B004T0YAMG/ref=sr_1_1?s=electronics&ie=UTF8&qid=1500782499&sr=1-1&keywords=rockford+1200.1
I'd consider the CAB 1600.1... buy a dual 4 ohm SA-12 and load the amp at 2 ohms (1200 watts or so)... and if you want to add a second SA-12 you can go to 1 ohm (1500 watts +) and the amp will be perfectly fine with that load... it's a little over rated power but I think a little extra is good anyways... and those SA-12's have a great reputation at being underrated... just mount the amp away from vibration (no box)... for $199 I believe it's a good buy....
Thats what it says, never heard of Magus.
Well you got options. Good luck.
---------- Post added at 11:36 PM ---------- Previous post was at 11:35 PM ----------
Me either... I just cruised thru all the other amps and goodies they sell and it is a candy store... I don't think they would sell garbage...
It's a cheap rebadge that's never in stock. Not worth worrying about.
Well the CAB is back in stock... it has been one of the forum "boners" for awhile... LOL!
Grendel0501
Grendel0501
Memphis Tn
youdoofus
