Alpine PDR-v75 or Arc Audio XDI 850.5?
amacura
I'm new here (but read these posts all the time) and probably should have joined a long time ago. I need some help. I have two questions:
1) Which is a better quality amp Alpine PDR-V75 or Arc XDI 850.5? I know that the pdr is not the same level as the pdx, but is there a major difference in quality?
2) I have seen where the PDR amps wattage are a little underrated. EX. specs show 350 watts on the sub channel 2 ohms, and actual wattage on one was 427. Is this true.
I hope you can help me by answering these questions.
I'd go with the Arc. I love my Arc KS900.6. Their XDi line is one of the better Class D line of amps. Their customer service is very good, as well.
I have a Jl audio 10tw3 for my sub that's already installed which calls for 300-400 RMS. If that tells you anything. Single sub. I wish I could do the pdx....just can't right now.
400 RMS tells me it can handle noise for a few hours no stop at 400 watts.
Something we don't do. Don't get to caught up in one spec. Sure you can blow a speaker from too much power but it will take way more then a 400 RMS amp since they rarely produce 400 watts. Any amp.
It's the W3 a SVC 2?
Features and Specification
SPECIFICATIONS
CEA-2006 Power Ratings
CEA-2006 Power Rating: 75W RMS x 4 + 250W RMS x 1 (4-ohm, 14.4V at
RMS Power Ratings
Per channel into 4 Ohms: 75W RMS x 4 + 250W RMS x 1 (14.4V at
Per channel into 2 Ohms: 100W RMS x 4 + 350W RMS x 1 (14.4V at
Bridged 4 Ohms: 200W RMS x 2 (CH-1/2/3/4, 14.4V at
Sound Tuning
Crossover Frequency (CH1/2/3/4, HPF): 50 Hz - 400 Hz, -12 dB/oct.
Crossover Frequency (Subwoofer, LPF): 50 Hz - 400 Hz, -24 dB/oct.
Subsonic Filter (Subwoofer): 8 Hz -40 Hz, -24dB/oct. (Variable)
BASS EQ (Subwoofer): 0 to +12 dB, fc=50Hz (Variable)
Dimensions
Foot Print (WxHxD) mm: 270 x 50.8 x 165 mm
Foot Print (WxHxD) in: 10-3/4'' x 2'' x 6-1/2''
General
Power Requirements: 14.4 V.DC (11-16V allowable)
Input Impedance: >10k ohms
Frequency Response (+0, -3dB: 1W into 4 Ohms) for CH-1/2/3/4: 8 Hz - 45k Hz
Frequency Response (+0, -3dB: 1W into 4 Ohms) for Subwoofer: 8 Hz - 400 Hz
THD+N (10W into 4 Ohms) for CH-1/2/3/4: 0.02 %
THD+N (10W into 4 Ohms) for Subwoofer: 0.02 %
Damping Factor for CH-1/2/3/4: >500
Damping Factor for Subwoofer: >1000
Signal to Noise (Rated Power into 4 Ohms) for CH-1/2/3/4: 105 dB
Signal to Noise (Rated Power into 4 Ohms) for Subwoofer: 110 dB
Weight: 2.76 kg/6lb 1.4oz
Input Sensitivity (RCA Input,CH-1/2/3/4): 0.2 - 4.0 V
Input Sensitivity (RCA Input, Subwoofer): 0.1 - 4.0 V
Question that doesn't have to do with amps. Ballistic around the door speakers, is it worth it or is it a sales pitch for more money? I just remember many systems that sounded crazy and they didn't have Ballistic material.
Ballistic? Yes door treatments are extreamly important. Look up what a back wave is.
---------- Post added at 12:36 AM ---------- Previous post was at 12:35 AM ----------
Arc over nvx and hertz.
KS yes. XDi not so much.
---------- Post added at 12:36 AM ---------- Previous post was at 12:36 AM ----------
amacura
amacura
jackson ms
dsw1204
