Best amp for CDT HD-62?
Yes sir!! I absolutly agree. If you put that much to them your going to have problems with the crossovers sending the tweeter section into protection.
Also even with 180 and the 560 x-overs you will want to be carefull. make sure you HP them correctly. They wont like 150 per side infinate baffle with a low x-over point. I know this from experience.
Exactly what do you mean by low x-over point? becuase I`m about to get a pair of the 560s to replace my 480s becuase you`re right,I ran into tweeter protection trouble with my hds and I was`nt even pushing them that hard (less than 100 watts) any heads-up would be appreciated.//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
The 480 has issues with the tweeter protection like you found. I set it off with anyhting from 45-200 watts per side.
What I meant about the crossover was on the amp. You want your high pass to be anything between 60-120hz.
IMO...
63hz for moderate volume rock
80hz for moderate rap
80hz for loud as funk rock
100hz for loud as funk rap
I have found that 80hz works well at loud volumes and 63hz works well for moderate volume. Just make sure you dont bottom out the mids.
APitBullT
APitBullT
Scottsdale, AZ
Johnny Drama
