Best 8" for Sealed about 0.3 cu ft. ~400-500rms
m48xhp
CarAudio.com Exclusive
Sorry, I know there are a lot of "What is the best 8"" threads, but I have read them all and not really found specifically what I am asking. I have 2 Eclipse XA1000 amps, that do around 500RMS each at 2 ohms. I am buying a C6 Corvette that has 2 small cubbys in the back that can be converted into sub boxes. They are very small and must be sealed. I want to make the install as stealth as possible, so something small.
I have seen people use weaker 8's that only do 100-200 w, but I want to get one or two to use my amps. I may just get 2 weaker and use one amp, but i want to try to get 2 and use both amps.
What is the best 8 that i can put on one of those amps that will fit in those tiny specs?
The Orphan 8's, some Audiopulse/TC Sounds or the regular Ascendants (if you can find them), e8's should hang, old ED e8A's (flat cone), and possibly the Treo SSi- though I know of no one who has actually heard one.
I dont care what anyone says e8's will not take 500rms mechanically. Mine would get sloppy and bottom out sealed with 3-400rms
carry on
carry on
Thats what I was thinking, although Ive read nothing but good things about them, and they are affordable. i can always get two and put them on one amp.
bump. bought the Corvette in March...needs a system. looking for buy now. still haven't decided. Id prefer just one sub. i am going to build a box sometime soon and see if I can squeeze a 10 in there. the inside volume is actually a lot closer to .75 cu ft or so.
m48xhp
m48xhp
Deep in the Heart, TX
m48xhp
