jordon
So I'm looking at any suggestions for two 2k amps that would be ran at .5 each and gained matched. This should produce better results than running a single 4k at .5 correct? power limit for the class I wanna run is 4k unclamped. cheaper the better being most 2k amps will yield the same results. also while here sub suggestions. I want to run two 12s in a trunk wall in this class. so each sub on a 2k amp @ .5. Goal is a 150 at 32hz. peak currently is 34 outlaw and 36 sealed. I know this will change with new and subs just give a general idea. also max box size is about 5 cubic internal after displacement. The smaller the better due to me able using an external port and sub box further back and seems to work best in my car. Right now dss primos seem like best option being with this power a 3 cubic box would be optimal.
