Benchtesting Amps
For starters you'll need a high amperage 12v power source (a car battery with a charger attached to it is a technically usable but not particularly advisable method of accomplishing this) which can prove somewhat pricey.
Having an oscilloscope helps too //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Otherwise, you really don't know if you're under the clipping threshold or not.
and can bench an amp by sticking ur tumb on the top dead center, and then u have to get a themometer and check how hot it is, and then divide that # by 2/ then add about 3-4 0's too it depending on if it is a A/B or Mono amp.... that should get ya going
What do you want to do,bench the amp to see what it's putting out at a given impedence at 14.4v (car on) or at 12.5v (car off acc. on)?
If you want to find what the amp is pushing at say 1 ohm with a 14.4v power supply then just hook up the DMM and the Clamp meter.
I saw a thread the other day that explained how to use the DMM and Clamp meter.
I think you use the clamp meter on your amps power wire where it connects to the amp and it reads the Current or amperes.
I believe you set the DMM to AC volts.
If your subs are wired to your amp at 1 ohm cool but remember impedence rise from box so what you measure may not be a true 1 ohm impedence.
Take the reading from the calmp meter and the DMM at the same time.
Multiply the amperes by the volts
example 40v x 100amperes = 4000w
Do the same thing to find the amps output with 12.5 volts power supply by turning the car off and only having the ACC. on.
Remember also to have your HU's volume up to it's max unclipped volume when taking the readings.
The real way is to have a 14.4v power supply and a resistor something or other that is able to handle a certain amount of power at said ohm/impedence/resistance but GL finding or affording those.
Real bench is done with the o-scope aswell to know the threshold of clipping.
Here is some info I found on Benchtesting....
Well, the easiest thing to do is ...
Test tone
Multi-meter or voltmeter that reads AC voltage
Resistor in desired resistance (If you want to test @ 1 ohm, you need a 1 ohm resistor) that can handle the power.
Test the AC voltage at the resistor (i.e. 40 volts)
Plug it into Ohm's Law (Power = Voltage squared divided by resistance)
Power = 40*40/1
Power = 1600 watts
If you don't have access to resistors, you can use your subwoofer, but it's usually not quite as accurate, especially if the test tone you choose just happens to be at a very large impedance peak ...
Also I found this with 2 minutes of searching the web...Dummy Load 33 ohm 500 watt power resistor.
It says you can parallel four of them to make an 8 ohm 2000 watt audio amp load (actually 8.25 ohms).
They sell for about $15 shipped each....http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270021303748&category=4664
KRD
KRD
ARIZONA
Phreaker
vegang
vegang
