Beginner's guide to box building
If it's ported, and the port is on the left side, I star with the back wall, and right side wall... Nail/ screw, and glue them. Let them dry. Then I do the front wall, then the port, then the left outside wall.
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif How??
Must have worked it's way loose from the vibes of the sub:confused: Only thing I could figure, I know when I closed it up they were on 100%, and they were pointing up, so it's not like the wires were hanging pulling down on the connection. Glad I caught it when I did, I have pictures somewhere.
which order does everyone glue their sides on, and how long should i wait for the next side?
I use the same technique on every sub, ported or not. Start with the bottom piece, glue on a full length piece (for me, I have all panels screw into the front and rear baffles, so for me, it's the sides). Then, glue on one of your side/baffles that you haven't used yet. You should now have three different pieces glued together representing the XYZ axes if you look at their common corner. Then, I glue on the other side/baffle that is the same as the one you just did, just opposite the enclosure. This leaves you with the side of the box open, with four panels together. This way, I can build the port up and build the rest of the enclosure around it. If that doesn't make sense, just ask me and I'll show you with pics. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Im going to be starting my first box soon and i was just wondering if i need to put anything inside the port to reduce port noise and sound better or something like that. Or something around the whole inside of the box
this should be a sticky right at the top.
who can get in contact with a mod to make this a sticky?
-=Jason=-
Go down to bottom of page and click on a mod and send them a message with a ling to this maybe. They will either A. Ignore it. B. Sticky it. Or C. Ban ya for buggin em. /shrug
PV Audio
The Vision of Sound
PV Audio
Indy
alvitae
BP1Fanatic
BP1Fanatic
