before i test out my subs
Bavarian3
Ownz joo
so i just screwed it my subs to the box me and my friend made. everything looks great. i pushed one of em and thot it was funny how i push one and the other goes out. but as i did this i heard a sound of air swishing through something. i put my hand over the wire terminals in the back and i felt a little bit of air coming through it. I havent tested out my subs or anything yet, and im afraid that this air coming through the terminal will cause problems or is it fine? what should i do.
yeah, take it out.. if possible, and then put a crapload of caulking to seal the terminal cup. Let it sit for a while, and then test again for leaks. If it still leaks, patch up the hole that is for the terminal, and then just drill a hole barely large enough for the wire to pass through, slide the wire through, and put a bunch of caulking around that too.
Silcone is also good if you want to use it instead of silicone. I used some crap called "does it all" (can't remembe the name) but my dad had it lying around.. he seals tile floors w/ it, so it must be durable.
no, it's something along the lines of "does it all". we had liquid nails too, but we didn't use it.
I think pure silicone is best for sealing leaks, just because of it's properties when it dries.
It may. You never know. The subs could just have enough pressure to blow it off. It would be better if you took the terminal cup out and put a bunch of caulking around it.
Bavarian3
Ownz joo
Bavarian3
Nor*Cal
gellis4
