Before I buy
fozzymuphet
Hi. I'm about ready to purchase a sub and amp for my bmw 325ic and i'd just like some help if there is some better equiptment in my price range
sub: ROCKFORD FOSGATE HX2 POWER 2000 WATS
this is on ebay and i see it going for about $200 US I'd like to stay in this price range although i dont mind the size so much. 12-15inch is good. So, whatever is the best in that size/price range.
amp:Hifonics 'BX1205D' 1200W Mono Amplifier
This is the same price as the sub $200 US. I've heard alot of good things about this amp and that is why i chose it. I'm pretty new to all of this sub stuff but i build custom computers for a living and i dont see how this could be much harder. Basicly i need a list for parts.
Music: I listen to Rap with Heavy bass mostly (aka Lil John and the eastside boyz)
thanks for the help
My budget for the 12-15inch sub and amp is about $400-500
Edit: I'd prefer a 15inch sub and i'm looking for SPL not SQ (although i would still like to listen to music out of it)
That is no lie... Those HX2's are some monsters. With 1200w to a single 15, in the right box, you should be VERY happy. (I used to own a pair of 12's)
And that amplifier is a bit over rated, but it should push the sub nicely at around 900-1000 w RMS.
I've changed my mind to useing this sub
Alpine SWX-1242D 12 inch Subwoofer
It runs dual 500w rms coils at 4ohms which i think means 1000w RMS at 4 ohms. Correct me if i'm wrong. Now, should i run 2 500w RMS 4ohm amps into it or is there a 1000w rms amp i can get for about 200 bucks on ebay? I only want to pay $500 total for the sub and amp but i really want this sub. Should i go with the SWR which is half the power handleing and use a smaller amp? I can get this sub for $250.
My car is a BMW 325ic
just found a Phoenix Gold Tantrum 1200.1 Class D 1539.5 on ebay for about $170. How do i overvolt this to 14.4 though? that's the only way i can get enough power to run this at rms. Otherwize it'll be at 250w at 4 ohms. I have a new battery i think but a stock alty
That amp does not do 250w @ 4 ohms... It it rated to do 1200w at 4 ohms down to 2 ohms. To get a 14.4v stable electrical system, you could try doing the big three, and getting a deep cycle battery for under the hood. I doubt this will bring you to a true 14.4 though, so a HO alt should really be brought in. But the amp will do fine with a standard 12v system, should do somewhere between 900-1000 wRMS
Sir...
the Alpine Type R subwoofer you said, is 500w RMS(continuous) power. It has a dual voice coil. The sub itself does not determine how much power you have, it determins the power you need, speaking generally. If it is a dual voice coil 4ohm, that means you can run one subwoofer at either 8ohm or 2ohms. It gives you different wiring options, that's about it.
Stick with the HX2 and get a relatively decent amp.
If it is a Dual 4ohm sub, get an amp that is rated aroudn 1000w at 2ohms, like a JBL 1200.1 That is agreat amp, there are plenty for sell on this forum, and it will do waht it says.
Sir...
wow Thx. That's helped me alot. I've read alot of good things about the alpine and it seems to be the word on the street. So a 2ohm amp at 1000w is what i need not a 4ohm amp at 1000w. Cool. What about the amp i mentioned? It seems pretty good. For about $250 shipped is there a better amp for SPL on ebay? If you really insist on the HX then i'll get it but it just seems to me like the Alpine is in a different category than the HX
Rockford Fosgate 15" T215D4 Power Stage 2 Subwoofer How does this subwoofer fair? Will it run well with a Phoenix Gold Tantrum 1200.1 Class D am that birthed at 1539.5?
fozzymuphet
fozzymuphet
Olympia, WA
fozzymuphet
