Beast 10s that require small boxes...
I run 3 sundown z.2 10's. In 3.5 cubes net. Super loud for 10's. Haven't metered yet. But on the ear-lab id say its on par if not greater then a single 15in BTL. Not sure it helps you at all but figured id throw my input in.
You lucky man you. And it better be louder than that!
Hahahaha exactly what I was thinking.... Hell, two 10's better be louder than a single 15" BTL..... 3 should walk on it.
Well 2 Zs will be a little less cone area, and a little less power handling. But if done right, the motor strength should get it there! And yes, 3 should be savage!
it is, i ran the BTL in 09, between then i havent had a decent setup. Its much louder then the BTL sealed up for sure. But I never metered either setup so it would be a lie to say, its for sure louder. The BTL was tuned at 30 this is around 31 or so. Much more musical then my BTL was thru the full srange
How much power for each set up?
Orion 2500d for the BTL at .7 and a audiopipe 3k at 1.5ohm both daily. The orion was on stock alt and a 160ah SLA battery in the back, the AP is on a mechman 270amp alt, redtop up front, and a Juicebox45 in the back (same size/specs of a xs power d1200)
Yes I bet those 3 10s are vicious!!!
You can always find one of these bad boys.....
The_Grimy_One
The_Grimy_One
Phoenix, AZ
ShawnT
vegang
vegang
