Bazooka C.H.I.L
mental_help
13
GA
i have 2 10" bazooka chill subs and i see that to git the chil system to work i need to by the adapter to screw into the bottom and then hozes conect to the bottom then out of the box but then what like where am i spose to put the other ends of the hose to how am i spose to git liqued pumping through it thanks in advance =]
Im sure its not worth the trouble to be honest with you man.
I know nothing about this but it seems like liquid cooling would require a pump and all that... but really with those subs its wouldnt make any difference.
And if the bass (or little there is) cracks something or makes it **** up or brakes the pump you could get water on your subs or amp and then youve got lots of mess.
I believe you need a seperate cooling pump that pumps anti-freeze like solution through the magnet to disapate the heat.They also made an amp that was designed the same way but have never seen it in use.Not worth the trouble or money IMO.
mental_help
mental_help
GA
azeroth123
BP1Fanatic
BP1Fanatic
