Today I'm getting my alternator rebuilt so I'm going from 50Amps to 85Amps. My plan is to run 1000wrms at 1.34ohms so with 80%amp efficiency I should drain at most (on 50hz -0db bass hits) about 34Amps. My battery is rated at 325CCA and 45RA and was bought last year.
I'm also going to be upgrading to 4ga wire to the amp and I have 2/3 of the big 3 wires upgraded to 2ga, the only one missing is the +ve batt to alt which I believe is around 6ga. Haven't done it yet because I'm not sure how to go about it, because the +ve batt is actually connected to the starter motor.
I just wanted to know if I could go another 2-3 years without needing to replace the batt/alt on this setup. As far as I know 1000wrms is alright on stock electrical systems but I figured stating my specs here I can get a bit more feedback on it. I can turn down the power draw if I need to.
I'm also concerned on how battery life is affected by being drained, in almost a year of use this battery has seen it's been drained 2 times. As far as I know they have a life expectancy of around 5 years. The brand is "Century". Though with the better alt I'm betting it'll get charged up nicely and it won't be much of an issue anymore.
Cheers.
Cheers.
