Basslink II Question
gomab2k4
I want to buy a Basslink to my 2003 Mercury Marauder (Crown Vic/Grand Marq). The potential problem I may have is the fact that my trunk is made up of four plastic compartments. Looking at the instruction booklet and pics of the Basslink, it requires that I screw it down into the trunk. Since my trunk is plastic, I do not think this will work in my car. Am I safe to assume this? If itcan not be screwed into the plastic, what other options do I have?
Also, how would the Basslink II compare to this Bazzoka...
http://www.sasbazooka.com/productAutoRawWoofersEL.asp?id=321
Please note that it is not the traditional amplified subwoofer that you would expect? I plan on keeping my factory deck and speakers, and I do not want a permanent setup for my lows. Please keep in mind that my car is large.
If I go with the Basslink, I want to add the optional 4-channel module. Alot of people say that the module will not make a big difference in sound for my highs compared to my factory deck. Is this accurate?
Hook and loop tape AKA Velcro. The Marauder has a big trunk, im shure you dont even need to secure it
The bazooka tube is complete garbage. I have not heard the Basslink II but the Basslink I totally kills the bazooka tube for output and clarity.
The module will probably make 0 difference and cost you money you dont need to spend.
Another concern...
Upon researching on the internet, it seems like the amp on these Basslinks tend to go out. And since it is intergrated, it pretty much ruins the whole system. Is this something that I should seriously consider?
gomab2k4
gomab2k4
Jonesboro, AR
phyphoestilic
