Bass Tasting
This is one of the reasons why you run a fused dist. block right here folks..its cheap, and easy to do, and can save your vehicle, and components. you sure its rated for 4ga wire??I didnt think it would be,i could be wrong though.Ive never understood the reason for oversized power wire either??Use whats rated..What was used @ the battery??Fuse?You are very lucky your vehicle wasnt up in flames...how do you explain that to an insurance co??Well,looks like it may be a good idea to yank all that power cable back out for sure,and replace it,im sure its crystalized somewhere in line
Be a great idea to upgrade your power wire to a min.of 2ga,or go 0ga, and run off of a fused dist block with 4ga wire fused properly for the next amp/amps to keep from this issue..is that amp only rated for 4ohms bridged as well??May have been,,???
GPcarAudio.com
Pro Seller
Supporting Vendor
GPcarAudio.com
Missouri
GPcarAudio.com
