bass shuts off
Originally posted by sk24iam In my firends car he has a rockford amp pushing two rockford subs. When we play the system, after like 20 minutes the bass shuts on and off randomly. Why is this happening?
your ohm load is too low and the amp is using its emergency shut off most likely.....
what amp? what subs and what is the voice coil config on the subs?
also, check all your connections to make sure they are secure
-nate
i meant 2 subs at 2ohms. the amp is capable. ist is a 2 ch amp and is bridged.
o, and is it ok for the ground if he just took a hole in the trunk and put a nut and bolot through it and hooked the ground to that?
sk24iam
sk24iam
LI
sk24iam
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
