bass shuts off completely help
systemJLx
Lately ive been noticing that every now and then, my bass will just shut off and i wont have any bass for what im listening to. Could this be signs of my battery not being able to support my amp?
I dont think its the fuse, because i got a pretty big JL fuse on there right now. In the past i did burn out 2 fuses that weren't JL tho, and they werent as big.
what do u guys think is going on?
what kind of battery do you have.
I have an Optima Yellow top, and my power wire wasn't tightly connected to the battery terminal, and that caused my bass to power off.
After I tightened the connection, it stopped shuttin' off. So try that.
If that isn't it. Run a ground wire from you battery terminal to your AMP. * That'll make it a perfect ground *
If it continues, battery needs to be checked out, upgraded, or alternator might need attention.
^^Probably a loose wire. Is the amp going into protect or overheating? Might want to check your ohm load, but if you say this just started happening, then most likely a loose wire.
systemJLx
systemJLx
florida
mapolley07
