Bass plays when car is off!
Does he have the factory HU or an after market HU? If its the factory HU just turn the GAIN down on the amp unitl the BASS goes away, it should not be much.
Wouldn't need an LOC with an aftermarket HU ... unless its old. Very old. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The GAIN is too high on the amp..Turn it down slightly, problem sloved........//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Gain setting wouldn't be the problem. The amp stays on after the car is off, and there is a signal through the RCA's as well.
If the LOC he's using has both the RCAs and a remote wire, thats the source of the problem.
True, amp should not stay on after car is OFF. Remote needs to be fixed....If you get a loud deep bass after turning the car off for a sec or 2 then the gain is too high.
factory h/u
i have seen this problem before. he needs to run remote line off acc or ign using a relay. otherwise you are sending no signal when car is off so it sounds like a constant 50hz.
i have seen many shops just splice into it in the fuse box which is wrong and shit like this happends.
I usually run the remote through the fuse box splicing from the RADIO fuse or anyother fuse that loses power when the ignition is off. Thats how I have my wifes car right now with no issues at all.
Slammed
Striking Accord
Slammed
Gotham City, NY
nismos14
