Bass out of Sync and can't figure it out.
  • 2
ps2cho
LA
Overall equipment installed in my 2016 Audi A4
Audiocontrol LC2i (installed in-place of the factory subwoofer speaker wires. so Factory sub -> LCI -> Amp -> Subwoofer.)
JL Audio JX5001/d
Infiniti 8" 850w Subwoofer in custom box, 22 x 15 x 4.5" which equals ~0.50cf
KnuKonceptz 8 gauge amp kit
Problem is that the bass seems out of sync with the music by a fraction of a second.
I just don't know what to try here.
Also, I don't know how to set up the LC2i properly...When should I use the bass setting on the line converter vs the bass boost on the amplifier? I've tried to aim for 29v total playing a 50hz test tone (4ohms speaker with 250w RMS = 29v)
Any ideas?
JL Audio JX5001/d
Any ideas?
so, you might not actually need the line out converter. I did the same thing in my old Maxima and went to a junk yard and bought the molex plug off a blown factory sub, used a dmm to find + and - from the wires for audio signal, power and ground were cut and capped on the plug leads, then grabbed the remote turn on for the amp. Cut the end off an RCA and bell capped it to the leads from the molex plug and connected the remote turn on all to the amp and viola, it worked like a charm. May want to look into this as it'll very likely work for you too
also, NEVER use bass boost unless you want to clip the **** out of your sub and decrease its life span dramatically. 8 gauge power wire from the batt to the trunk is good for about 500 watts or so, and youre not gonna get a ton out of that without the aforementioned potential clipping issue.
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
180
Defiantly. LOL 😂 It has never happened to me👀:poop:
310
Maybe voltage loss? I always set my LFP to 80 and on steeper slope with no noticeable SPL loss. Playing a sine wave is a lot easier on your...
420
ps2cho
ps2cho
LA
youdoofus
slater
    May 2, 2024
slater
    May 2, 2024
