Bass lowers when turning? wierd problem. help!
srch4aresn
some info:
1993 grand marquis
alpine head unit
infinity speakers
jl 250/1 amp
jl 13.5 sub
alright. all of a sudden, whenever i would make a left turn, like making a u-turn at a red light or whatever, my bass would drop to like half the volume, then once i straightened out my wheel, it would go back to normal volume.
now, its **** near stuck at that half volume, and only when i turn right, again like a hard turn when you turn into a plaza, the bass jumps up and gets loud again, then goes back down.
im guessing it has something to do with a ground, but what the hell could be making the bass increasing or decreasing from turning the wheel??!?!
any help will be appreciated!
some info:1993 grand marquis
alpine head unit
infinity speakers
jl 250/1 amp
jl 13.5 sub
Pix of install plz. Impossible to know without seeing it.
Map out routes to all your favorite places that only allow for right turns. It will become second nature after a while.
Best advice I have ever heard on this forum. Op this is clearly the only way to fix it. Your car does not like teh deeebeeez
im baffled.
took out the head unit, all wires connected and rca plugged in all the way
checked under the hood, all battery connections are good, amp power cable to battery and fuse connections are good.
went in the trunk, all connectionss to the amp are good, no loose wires. ground to the trunk is good. wires to the trunk battery are good.
i have no idea what the problem is.
i know what my system sounded like when i first hooked everything up. on the head unit i had bass at like -4 and subwoofer at 10 and it was much louder than NOW with the bass at +2 and subwoofer at 15. just pisses me off.
srch4aresn
srch4aresn
Palm Beach
Wingman0121
