Bass cutting out
Dont mean to thread jack or anything(even tho i might) But if you set your gain all the way full on a say 1000w amp does that mean ur pushing 1kw and if its halfway only 500w?
Amps can get a little hot, but if it starts to burn your hand after just a few seconds, then yeah it's overheating.
*provided the amp isn't sitting in direct sunlight*
I tore the HU out and checked all my wiring, changed the ring terminals on power and ground but now it cuts out when the volume is low. when it is high the bass pounds but sometimes when the volume is lower or there is a track with little bass, the subs completely shut off. I watched the amp when this happened and it wasn't going into protect mode and stayed on so not sure whats going on now.
jharijan
jharijan
Boynton Beach, FL
jharijan
ThxOne
    May 13, 2026
