bass blockers????
If they are on that 450/4 I suggest raising the HP to "block" some of the bass.
wherever it is now raise it to 80-90hz. (keep in mind you may have to adjust your subwoofer amp's LP to around the same value)
also check to make sure the amp is on HP
maybe they are exceeding your expectations
Do you have any bass boost on that amp? if so turn that down and also mess with the gains a bit to see if that will help. I don't know what if your deck have a loud button but, if you do don't use it...
spike_e
ballin on a budget
spike_e
prattville AL
Ptown_TSxxx
