Bass Blockers???
cazorp
ok well i bought some stinger bass blockers for my front and rear speakers, the only problem is there is a wire coming out of boths sides of every blocker ... do i connect each side to a speaker or do i splice the bass blocker into the other two???
thanks
Zach
ok thanks
which one is positive if i do it behind the dash though???
thanks
Zach
get someone to help you. take a battery, like a cordless drill battery or 9 volt, and hold it on the speaker wire. have the other person look at the speaker with a light. when you touch the wires to the battery if it moves out then in, then whatever wire was touching the + side of the battery is your + wire. if it moves in then out, the you have it backwards. this is also a good way to check your wiring when connecting it to an amp, to make sure everything is in phase.
cazorp
cazorp
Shreveport,LA
rocky 59
AJ (ACE)
    Jun 28, 2026
