Badd ground ? what do bad grounds do?
iivan
i just connected my 4 channel amp
(2 channels to 6 speakers (my 6x8 my tweeter and my 3.5)
(2 channels to my rear 6x8)
i think i have a bad ground cause i see the amp light dim a lil with my highs on only
after about a full song it sounds like the amp isnt putting its full potential
can i be the ground?
im running a 4 Gauge Bullz audio amp kit( low end amp kit) to my battery which is in the back
what are effects of a bad ground? are some grounds better than other ground places?
How/where did you connect your ground?
It's not a ground issue it's most likely incorrect gain settings along with the fact there are not many 4ch amps that will run around a 1ohm load per channel and if they will they get hot fast and require a lot of current to do it at all. My Rf T600.2 will run at 1ohm per ch(or 2ohms bridged) for about 30minutes then it overheats, he needs to wire the speakers properly or use a x-over to disperse the signal to the 3 speakers in each door.
thank you muchh!! muchh!! appreciated it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif can i leave my tweeters and my 6x8 on at least?
yea my local shop rigged that setup stupidly
are you running comp type x-overs or just a bass blocker type and when this happens are the tweeters going down in output and then returning when the volume is reduced?
iivan
iivan
United States
iivan
