Bad RCA Outs?
SilverLade
Hey guys I have a pioneer DEH-3200UB headunit in my truck. I am currently installing an amp for my mids and highs, my question is if I have bad rca outputs? The back of the deck has 4 rca's in total 2 for subwoofer and 2 for front output, well I had to buy some Y cables for the 2 front outputs because I'm running a 4 channel amp and with the Y cables installed and brand new rca's when I connect them to the amp it goes into protection mode? Well when I run rca's from the subwoofer rca to the amp it works fine. So is it bad rca jacks or something else? Any suggestions and help would be much appreciated!! Thanks in advance!!
Have you tried it without the Y cables?
Try to plug in 1 set of the front RCA's to 1 side of the amp. Then try the other side of the amp. Then try the other set of RCA's
Try to rule out if its the y cables, the rca's, or a specific side of the 4 channel amp.
Thanks for the help man! I've tried EVERYTHING, no y cables, all the RCA's on the amp and it still does the same thing. All my stuff is brand new, the amp, all wiring, fuses etc... it's really a pain that I can't figure out what's wrong
SilverLade
SilverLade
Pine Bluff, AR
Vossy
Mike Mccabe
Giles
    Jun 27, 2026
