Bad habits
last week i read an article saying that if you ********** too much you can become depressed because ejaculating your hormones can eventually cause some kind of hormonal imbalance causing you to be emo or something like that. Anyway, Im having a very difficult time cutting back on masturbating //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Sometimes I leave jizz in the shower drain and it really pisses the wife off.. Sometimes I remember to make sure there is nothing there and push it down with my toe if there is but I forget a lot //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
the trick is to rub the drainage holes in a circular motion with your big toe until it feels rough. But if you feel a thin layer of stickiness between your toe and the drain you need to apply more pressure. Sometimes, the sperm can be too thick and will refuse to go through the hole. This is when you need to force it down the hole too. Its kind of like peeling a layer of elmer's glue off the drain except that it will be less adhesive but a lot more thick and sticky. good luck man
barneythedino
barneythedino
Florida
DykeOfTulsa
