bad engine wine NEED HELP!!!
Kal1877
So I just got done installing my new comps and amp. Everything was working fine. Then today on my way home from work I went to move the tweeter and I heard a loud noise through the speakers. This is when the engine or alternator wine started. When I got home I checked the ground and made sure everything was good after that I still had the noise. I then disconnected the rcas and no noise. Could it be bad rcas or something else??? please help!!
Did the noise start right when you were moving the tweeter or after?
It's possible you tweeked something in the amp if you grounded out while the power was on.
I dunno, I always got to say. If it worked before and it isn't now, what did you do to make it stop working. Retrace your steps to find the cause.
It is possible the speaker wire got grounded or cut or maybe it is now to close to some power wire running through your car.
I get a horrible hiss and pops if my Sub speaker wire is too close to my mid/high RCA's. You can tell it's not engine wine because it doesn't go along with the rpms.
Kal1877
Kal1877
Scranton,PA
Kal1877
BP1Fanatic
BP1Fanatic
