bad engine noise
rival904
Ok, Let me explain this as best as I can.
I have 2 4 channels, both mounted to my amp rack, I have them on 2 distro blocks for power and ground(1/0in and 2 4ga out)
I have engine whine pretty bad, and have tried almost every trick in the book.
First off, I am not running a headunit right now, just iPod into the EQ.
The amps are grounded roughly 3ft directly to my 2nd battery.
The EQ is grounded the to chassis
If I unplug the RCA's out of the amps, the engine noise stops
I have tried a new set of RCA's, notta
Power and RCA's are ran on the opposite sides of the truck
I purchased a Stinger ground loop isolator from Darvex, still there and noticeable.
Now, in all reality, Im sure the engine noise isnt that bad, but when you have 8 pro audio style 6.5s, everything's loud.
I can drown it out by cranking it up really high, but In my mind its still there.
I also have a train horn installed, and when the compressor kicks on, I can hear that through my speakers also(compressor is grounded to the frame of the truck.)
Any other ideas?
Any other ideas?
try a different signal into the eq. if noise is still there then
run just the ipod into the amps is the noise still there? if not then run some rcas outa the carpet from eq to amps and see if noise is there. eliminate one item at a time till u find what's causing the noise.
rival904
rival904
my house
Horsemanwill
