bad battery
Your battery is your power supply for your amp. Your amp will not be getting the current it needs to produce the power your asking of it. This is not a good thing. I believe this can cause clipping but im not 100% sure. Buy a new battery before you toast your alternator, your amp, and your subs.
if thats the setup in yo pic, the box looks extremely to small
From what I have read Type R's get louder in small boxes as long as you have the power.
His sig says KAC-9104D which isnt enough power and the picture shows a Legacy Ice amp which still is kinda weak.
well this guy defiantly doe not have "the power" he is running 450rms/max to each //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
if your battery is dead i'd be more concerned with your car starting and being reliable than your stereo //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
ha ha yea he ditched the legacy to get a "better" amp wich is only "900/w rms" you can look at his past thread on hoe to wire it to one ohm he tested without the car running then he said he had "alternator whine" without the car even runing then he said the amp "must have finished he alt off"
http://www.caraudio.com/forum/showthread.php?t=333131
he is an idiot and a ***
i believe i have battery or alternator issues. That probably explains why the bass keeps cutting out. I can't even start my car right now so it must be alternator or battery problems.
endofdays89
Banned
endofdays89
missouri
zack39648
