bad bad bad
brybry354
i was installing my new amp and i had a problem and the KickerZX1000.1 class d amp had a red light.
so i checked all my wiring and the ground wire was loose and as i went to fix it, it dropped out and like an idiot i did this while my truck was running and a spark flew out the side of my amp and made a loud pop sound...
is the amp trash?
i was installing my new amp and i had a problem and the KickerZX1000.1 class d amp had a red light.so i checked all my wiring and the ground wire was loose and as i went to fix it, it dropped out and like an idiot i did this while my truck was running and a spark flew out the side of my amp and made a loud pop sound...
is the amp trash?
You tell me? Does it still work?
well no it doesnt still work or i wouldnt be posting this.
after the spark flew out the side the red light went off and it blew the fuse.
i replaced the fuse but every time i go to hook it up to the battery it arcs like crazy
my negative terminal is hooked up...
my power cable runs through the fuse holder and hooks up to the positive.
right now the positive is not hooked up.
brybry354
brybry354
Texas
Supergumby5000
AJ (ACE)
    Jun 28, 2026
