B2m1s or sundown ns1 v2??
Pretty easy choice. Depends on where you charge. The b2 is optimized for 12v setups. The ns1 does better on higher voltage.
I too would take an ampere or Ts 8.5k
The ts and tfe are optimized at 14.4 volts. But still strong. I'd go ampere or b2 myself
Well 14.4 is a 12v system. 14.4 is where a 12v system charges at. The b2 is the one best optmized for low voltage, however. Talking like sub 12v. I know for sure that the tfe, and likely the ts, is still stronger at 12v than the b2. But it really isnt a fair comparison as its actually spec'd as an 11.5k board from xenon.
I'm a huge fan of amps that make voltage low. Love DD amps for that reason. But the tfe and ts are a different class of amp.. But the m1u, now you are talking
The tfe 8.0 is actually a b2 m1u proto type from 5 years ago. That was scrapped by b2 But yes the m1u tfe 8.0 and ts 8.5 are pretty much the same amp to a point
I hear what you guys are saying about the ampere and twisted but I am going to be running two zv4 or zv5 18" s so I think those and the m1u would be to much for a daily set up. I will be using a 14 cube enclosure at 35hrz.
I hear what you guys are saying about the ampere and twisted but I am going to be running two zv4 or zv5 18" s so I think those and the m1u would be to much for a daily set up. I will be using a 9 cube enclosure at 35hrz.
Why ? I run a pair of shd 18s on a m1sr at .7 for daily
81000d
81000d
novi Michigan
mylows10
slater
    Oct 4, 2025
    Oct 4, 2025
