Due to a new family member i decided not to put in a sound system i had plans on putting in my car. Need money to make a baby room instead. the system consist of the following all BRAND NEW never used. I will give a description with each item. I want to sell this as one full sound system with out breaking it apart. But i guess if the price is right i will break it apart.
2 BRAND NEW never used before TREO SSi SSI12.44 12" DUAL 4-Ohm SUBWOOFER
# Precision CNC-machined low-carbon steel motor structure with durable and attractive polished nickel finish (128oz on SSi 8.xx, 288oz on SSi10.xx-SSi15.xx, 488oz on SSi18.xx)
# High-flow large diameter hyper-extended vented pole piece keeps it cool
# Black color-matched strontium ferrite magnet
# High excursion motor structure and suspension design
# Five-layer Poly-ether UV-treated foam surround
# large-diameter high-temperature Nomex dampers
# Integrated tinsel leads for increased reliability and enhanced sound quality at high excursion
# Attractive anti-resonance Die-cast aluminum basket with TREO Engineering-exclusive perimeter venting
# Mica-impregnated polypropylene cone and dustcap
# 3.0 inch, high-temperature aluminum voice coils with integral heatsink on SSi10.xx, SSi12.xx, SSi15.xx & SSi18.xx
# 500 Watts RMS power handling on SSi 8.xx
# 750 Watts RMS power handling on SSi10.xx, SSi12.xx & SSi15.xx
# 1000 Watts RMS power handling on SSi18.xx
# Dual 2 Ohm and dual 4 Ohm voice coils available for maximum installation flexibility
# Nickel-plated spring-loaded push terminals retain up to 8 AWG wire
# Optimized for small to medium sealed, vented, infinite baffle, and bandpass enclosures
# Hand-built in the United States from domestic and imported components
1 BRAND NEW never used before TREO SSX SSX2000.1 1-CHANNEL MONO AMPLIFIER *AMAZING AMP*
# Massive extruded aluminum heatsink with precision CNC-machined TREO Engineering logo
# Low-profile heatsink design allows many installation options
# Gold-plated terminals for all inputs and outputs
# All models can accept up to 8V RCA input
# All models feature cooling fans for enhanced heat dissipation abilitiy.
# Under/Over-voltage, thermal, and short circuit protection on all models.
1 BRAND NEW never used before TREO KNOB Digital Bass Restoration Processor
The TREO KNOB is a new digital signal processor designed to give you the power to re-inject lost bass into all of your favorite recordings.
When music is mastered low frequency signals are often downmixed or filtered out. Audio mastering technicians do this for a variety of reasons, most commonly because they believe a large portion of their listening audience may not have the right equipment to play low frequencies correctly. This is especially true for recordings mastered before the widespread adoption of large low frequency subwoofers in the late 1970s.
If you have TREO subwoofers and amplifiers in your car you definitely have what it takes to faithfully reproduce deep bass frequencies and we at TREO Engineering are proud to bring you the TREO KNOB to recreate the low bass you've been missing.
The TREO KNOB contains special circuitry that analyzes higher-frequency signals called harmonics and uses these high notes to re-create the low frequency audio information your TREO amplifiers and subwoofers were designed to bring to your ears.
We have also outfitted the TREO KNOB with a floating subsonic filter to keep your amplifiers and subwoofers working at maximum efficiency.
The TREO KNOB also has a dash-mountable level control that puts you in control of exactly how much bass you want to add. The powerful output signal and low output impedance from the TREO KNOB makes it the perfect accessory to control the subwoofer level of a subwoofer system featuring multiple amplifiers. Up to twenty amplifiers can be controlled by one TREO KNOB.
The TREO KNOB excels at bringing out the deep chest-shaking bass your TREO Engineering subwoofers were built to play in all your favorite recordings and MP3s.
so you get
-2 BRAND NEW never used before TREO SSi SSI12.44 12" DUAL 4-Ohm SUBWOOFER
-1 BRAND NEW never used before TREO SSX SSX2000.1 1-CHANNEL MONO AMPLIFIER *AMAZING AMP*
-1 BRAND NEW never used before TREO KNOB Digital Bass Restoration Processor with the dash-mountable level control.
im asking $1200 Plus shipping for everything i paid well over $1850 my loss is your gain. I need all this gone like i said before i want to keep everything together but if the price is right i will break it up. PM me with any questions. Thank you for your time.
* Will also toss in a bass knob for the amp free*
* I accept Paypal buyer pays fees, Money Order, Personal check will ship all items once the check clears *
*update* new pics up of the knob and the amp as you can see both item are brand new never used i can send more pics if necessary on request. Pictures of Subs will be up soon got to drive to storage pod to get them. Thought in there in my garage but wife just informed me she put them in the storage pod a few days ago. To free up space.
so you get
